HP Comware based switches and Identifi Wireless issue
Steve_Krasinski
I am looking for a little help getting our Identifi Wireless working with HP Comware based switches. We currently have older Hp Procurve switches that work just fine but the newer HP switches are running Comware. I have provisied the port just as I would on the Procurve. We leave the Management vlan untagged and the user vlans tagged.
We have it as such now on the Procurve.
vlan 12 mgmt untagged
vlan 102 staff tagged
vlan 104 apple tagged
vlan 108 android tagged
vlan 112 laptop tagged
vlan 116 gaming tagged
I have all the vlans setup exactly the same on the Comware switches.
I have tried using both Hybrid and Trunk ports and neither will allow the access point to communicate with the wireless controller.
Does anyone have any ideas on what I could do.
12 REPLIES 12
Ronald_Dvorak
Honored Contributor
Could you please provide the exact model name of the switch.
-Ron
Steve_Krasinski
PVID VLAN Passing
GE2/0/32 12 102, 104, 108, 112, 116
This is what it is setup in the Comware config. I have this port configured as a trunk port at the moment.
VLAN 12 is the Management VLAN that talk to our controllers.
Andre_Brits_Kan
Contributor II
Hi Steve
I presume that vlan 12 (Management) is the vlan that the AP uses to discover the Controller
Can you give me the port config on the comware device?
The port should be configured as a trunk port allowing vlan 102,104,108,112 and 116.
Then you will have to ensure that the native vlan (Untagged) is configured for vlan 12.
That shoudl replicate the config from the procurve.
