IdentiFi: 2.4Ghz clients unable to get IP
Ilya_Semenov
Contributor
Hello, team,
I have V2110 installation and 120 3825APs. Surprisingly, 2,4Ghz clients have stopped working. They unable to get IP. 5Ghz works fine.
What could be the reason of this?
Please, help!
Many thanks in advance,
Ilya
39 REPLIES 39
Umut_Aydin
It should be ..What version do you use ?
Ronald_Dvorak
Honored Contributor
Is that the same SSID that works for 2.4GHz & 5GHz and not even one client works on 2.4GHz ?
Do you use the load group feature on this SSID.
Ronald, I wasn't right. There is a Load Group exists. I've deleted it. Wait for a result.
Hi, Ron,
I've no idea what is it - Load Group Feature.)
Umut_Aydin
Hi Ilya,
did you made a upgrade recently?
What FW Version do you need?
Are all SSID's affected?
I would suggest to update to 10.41.07.
Disable 11k/MFP/fast Transistion
if enabled.
We need more details.
Regards
Umut Aydin
