Issue with wireless authentication/association between legacy Nortel SpectraLink 6120 and 3935 APs
jphillips1
Client:
Nortel SpectraLink 6120 handset - 802.11 a/b/g capable
The phone can see the SSID in survey mode but does not appear to be able to authenticate or associate to the AP. No client records found in logs. Client displays "No Net AP Found"
Infrastructure:
AP 3935i
5210 EWC running 10.31.03.0012
Trial and error:
We have tried turning off as many non-legacy features as possible, 20 MHz wide channels, enabling lower data rates, adjusting the DTIM (1,3, & 5), etc.
Phone is configured to use WPA2 PSK on 5 GHz - UNII 1 & UNII 3 channels only. Have also tested using the 2.4 GHz b/g and with same result. Have reset, changed, reviewed, and confirmed settings in the phones several times.
Any advice? Besides buying new phones...:)
8 REPLIES 8
Doug
Looks like a ticket was opened with GTAC.
Doug Hyde
Sr. Director, Technical Support / Extreme Networks
jphillips1
Thanks Pala!
Didn't know about the real capture remote option. I will use it as soon as our VPN access is allowed in the AP subnets.
Craig_Guilmette
Try these settings;
Disable Management Frame Protection.
On the QoS settings, enable U-APSD 11e WMM and Turbo-Voice
set ap's to DTIM = 1
Zdeněk_Pala
The realcapture can be done remotely. Your wireshark connects to the AP over TCP and you will see what is hapening. I do understand it can be difficult / challenge...
Regards Zdeněk Pala
