Load balancing or Band Steering which is better?
Sai_Prasad_Rao_
New Contributor III
Clients are getting stuck to the access point which they connect for the first time, they are not moving to other ap while roaming. I have enabled bandsteering for all those ap's. Is that causing the issue.... Just removed bandsteering and configured client load balancing will that help ?
18 REPLIES 18
FES
New Contributor III
i have seen that you have Long Guard Interval... Actually in my network that i have with 7000 clients I dont have 802.11b clients... yo may only configure Radio 2 with g/n.
By the other side, actually is posible that you have probles with probe suppresion.
https://gtacknowledge.extremenetworks.com/articles/Solution/Access-points-getting-into-a-locked-stat...
I dont see 9.21.08 version... Is it published now?
In avanced settings of Radio 2 you have STBC, LDBC, ABBDDA support that the help says that is recommended to be enabled. Consider see the help in each window to enable or disable your specific options.
I have more options configured different than yours, but depends of each network.
Apologize for my english
Doug
usually different compliance tables (ie max tx power for a particular channel)
Doug Hyde
Sr. Director, Technical Support / Extreme Networks
Ronald_Dvorak
Honored Contributor
Thanks Doug,
any idea what the difference is to the non -1 APs.
wns0014251
Added support for AP3825i-1 and AP3825e-1 models
Doug
9.21.08 has been released.
Doug Hyde
Doug
Hello Francisco,
The 9.21.08 release should be posted on our Extranet for download no later than tomorrow afternoon.
Doug Hyde
