Max cable length for POE APs
Ilya_Semenov
Contributor
Hello, everybody!
I have about 100 3825i APs, connected to x430-8p switches. Half of the APs works, the other - doesn't. I mean, the amber lights don't blink anyway like there is no signal
I suspect there is something wrong with cable lenght. Do you know any official numbers from Extreme related to the max cable length for POE devices in meters?
Tomorrow I expect a guy with Fluke and we will measure our cables.
Many thanks in advance, Ilya
6 REPLIES 6
André_Herkenrat
The X430-8p has a powerbudget of 60W (90W depends on EXOS Version). There is no chance that you can use all 8 Ports for an AP.
Try the show commands on the switch:
show inline-power
Cheers
Jeffrey_Bourger
100 meters maximum for copper - around 300 feet. Also, look at the POE switch - if using a Cisco 3560 for POE, only half of the switch can be used before the available POE wattage runs out. You can also try adjusting the POE threshold on the switch, using just enough wattage per device. Check the last pair - the brown wires, for damage as they are the ones used to deliver the power. Cheers!
