Probe Suppression/Force Disassociation
Joshua_Puusep
New Contributor III
I've been playing with Probe Suppression/Force Disassociation to see if it could help in certain area's with clients that do not roam aggressively, however it does not seem to be working. e.g. I have an ap with 16 clients on it, 4 of which have -80 RSSI. When i enable probe suppression, force disassociation with a threshold of -65, none of the 4 clients get disassociated. Any advice? Thanks much.
11 REPLIES 11
FES
New Contributor III
To improve roaming you must enable 8011.r (Fast Transition) at Wlan Service in Privacy tab. I have tested this option and the improve of roaming is significant. Also I have read that you have to enable multicast on ap's vlan to improve the roaming.
On the other hand, I just have read the recommended configuration in K12 enviroment and the min rate recommended is 24Mbps.
I think that you must configure specific values for each building or floor depending of the number of access points or users connected.
let me know your improvements.
Joshua_Puusep
New Contributor III
Thanks. We are already running 10.01.03.0007 on our controllers. We use a min rate of 12 on radio1 and 6 on radio2. I will look into increasing the min rate on radio2 in order to decrease the cell size. Is that considered a more reliable way to "force" roaming than probe suppression?
