‎06-14-2019 05:31 PM
‎02-25-2021 07:08 PM
How is that even possible? to fall asleep in between pings? if its a reply, like it is in this case (when it finally connects, even 2 seconds shouldn't be long enough for power management to kick the computer into sleep…
Thanks,
J.
‎02-25-2021 07:06 PM
Oh, and the other thing about removing the driver Windows 10 installs (most the time anyway) when its finished installing itself, is to fully remove that driver. Not just remove it via Device Manager, Device, Properties and Uninstall Driver, but to actually delete the driver. Once you do that, then you go to the manufacturer’s website, download the install their driver.
There is an article here on how to do that: How to uninstall drivers from Windows, in 5 steps | Digital Citizen
I have asked the desktop technician to try that and let me know if he is still having the same issue. So ill get back here when i hear anything, and would appreciate any more thoughts/solutions on this issue, as the above may or may not work.
Thanks,
J.
PS: If i didn't say it already, its an Intel card in this laptop.
‎02-25-2021 11:42 AM
I saw that about turning power management off, and according to the desktop technician, there is nothing in the device properties to turn that off.
thanks,
J (Jason).
‎02-25-2021 11:40 AM
Nope, just sitting in the office right next door to mine, where the AP is.
Thanks,
J
‎02-25-2021 07:22 AM
Hello J,
just as a note, the post refers to Identifi not ExtremeCloud IQ.
Regarding your problem, please check the power saving settings (in the wireless driver of you client). There are clients that fall asleep between pings and therefore take a long time to bring the ping to the WLAN.
