Purview Integration Wireless Controller 9.21
Michael_Kirchne
Contributor
Hi community,
has anyone integrated the wireless solution V 9.21 into Purview? I get the TopN Mirror up and running but I don't get netflow packets.
Netflow is configured in the section "VNS->Global->NetflowMirrorN"
There I configured the Mgmt IP of my Purview instance and choose esa1 as my L2 Mirror Port.
Any idea?
Best Regards
Michael
47 REPLIES 47
Welcome to the Hub Community David. Really great to have you join us!
Thanks Mike! I created a seperate vSwitch and assigned eth1 and esa1 to the port group purview is running perfectly! Great thread thanks for the quick responce.
6629788ef7fa4ba28d6b45f8dabad0e0_RackMultipart20160405-100042-dwiv7-Capture_inline.png
Purview will not be able to work with one interface.
It will need a eth0 and a eth1. And the ESA1 on wireless VM will need to attach to the ETH1 on the purview appliance. The wireless controllers do not support GRE interfaces, which is needed to run only one interface on the Purview appliance.
If in a purely VM environment, the ESA1 port and ETH1 ports will both need to be in a separate VSWITCH, in permiscous mode on both interfaces. Some unlicensed versions of VMWare do not support this.
This may not at all have been your issue from the controller side, but your topology does not sounds correct.
Luis_Mendes
Contributor
Yes... but i Have 2 c5210. And purview see the traffic but dont populate
