Sudden Issue - Few Users wifi connection says connecting to wifi and it doesn't connect
‎09-16-2016 03:38 AM
We have 2 - c5210 controllers with 3805i Access Points running on 9.21.10.0005. Everything was working well (with few disconnections here and there )all of sudden few users report "when they are trying to connect to Wifi they are seeing connecting to WiFi and they are not able to connect.
DHCP scope is fine
idle timeout settings : pre: 30 , post : 30 session: 0
Running both B@ap and B@ewc
Security: Open
Changes made in last 3 weeks : Disabled ADDBA and Aggregate MPDSU (which resolved client dis connectivity issues to a major extent)
Flexi Cleint access: Disabled on SSID's
DHCP scope is fine
Security: Open
14 REPLIES 14
‎09-21-2016 08:17 AM
When you are seeing the issue, if you look at the client by AP report, do they show connected there ? I have had a couple reports of that here and it seemed to only be 2.4 radio so far.
‎09-19-2016 03:27 AM
Hi Jeremy
As requested I have provided the radio 1 & 2 details, waiting for update from your side.
‎09-17-2016 05:38 AM
Hi Attached screenshots.....
‎09-17-2016 04:56 AM
What are you using for the advanced settings on the 2.4 and 5 ghz radios. Can you provide a screenshot of each?
‎09-17-2016 03:52 AM
4000+ users max Issue is same when there are 500 users connected. Each ap has less than 30 users.
