What algorithm is required in an Extreme Switch to connect an AP3825i with LACP enabled ?
Jorge_Cota
Good day.
What algorithm should be used in an Extreme Switch to configure Link aggregation and be able to connect an AP3825i with the LACP option enabled?
This is the command that has been used:
Enable sharing 1 grouping 22,23 address-based algorithm L2 lacp
The ports have the same VLAN, speed and duplex settings.
It is having problems signing this model to EWC and would like to discard the LAG.
I hope you can support me.
Greetings.
10 REPLIES 10
Doug
Reference: https://gtacknowledge.extremenetworks.com/articles/Solution/Ap-3825-fail-making-lacp-after-upgrading...
Doug Hyde
Sr. Director, Technical Support / Extreme Networks
Jorge_Cota
The solution was to download the firmware to version 10.21.04.0005, later, the APs with LACP (3825i) worked correctly.
Greetings and thanks.
Joshua_Puusep
New Contributor III
just to confirm, are you trying to aggregate them to different switches or the same switch?
We are implementing Idenfiti on a campus, and the 3825i APs are causing us problems using LACP on various Switches (Standalone and Stacks).
Greetings.
