What algorithm is required in an Extreme Switch to connect an AP3825i with LACP enabled ?
‎05-24-2017 03:06 PM
Good day.
What algorithm should be used in an Extreme Switch to configure Link aggregation and be able to connect an AP3825i with the LACP option enabled?
This is the command that has been used:
Enable sharing 1 grouping 22,23 address-based algorithm L2 lacp
The ports have the same VLAN, speed and duplex settings.
It is having problems signing this model to EWC and would like to discard the LAG.
I hope you can support me.
Greetings.
Greetings.
10 REPLIES 10
‎05-24-2017 03:10 PM
That's the version I have in the EWC.
Then before 10.31 this model if you worked correctly with LACP ?.
Which version did you have previously?
Thank you Faste.
Thank you Faste.
