Access Point still showing on Wireless Controller as offline after being physically removed (WM3400 & AP4600)
Sean_Tutor
New Contributor II
I'm currently using a WM3400 with AP4600s. (4620 in this case) We removed the AP4620 and replaced it, however it still appears on the web interface as offline. Is there a way to remove this AP from the controller so that others won't panic when they see the interface?
4 REPLIES 4
Sean_Tutor
New Contributor II
Thanks.  It was still there after I ran the command. For some reason the AP still showed up in the Config tab at which point I realized there's a delete button.... /sigh I deleted it and then commit/write and it went away from the dashboard. Appreciate the help! You can close this ticket!
BrandonC
Yes, you will need to commit the changes and then save the config.
Sean_Tutor
New Contributor II
Do I need to write to memory or anything else?
BrandonC
Hi Sean,
If you log into the CLI of the controller, then go into config mode, you can just do 'no ap4600 '. This will delete the device config for this AP.
-Brandon
