AP 6532 Led Indicators
12-04-2017 02:28 PM
Hi, I have 2 6532 APps that were working without a problem, now they are not responding, i reboot them and they doesn't come up, the LED Indicators are Solid Green and never change this State.
¿What can i do?, they dont have an console port.
6 REPLIES 6
12-04-2017 03:16 PM
You can enter via CLI to the Virtual Controller and send the following information:
show boot
show adoption history
show adoption status
show boot
12-04-2017 03:05 PM
Hello Leonardo,
See an article here:
What does LED blinking means on AP650?
As per the description you might be experiencing bootup or memory corruption issues.
Please consider raising a support case or RMA to get your APs replaced.
Regards,
Ondrej
Regards,
Ondrej
12-04-2017 03:05 PM
Hello Leonardo,
Here is one article about how to submit an RMA case.
Submit an RMA Case on the Extreme Portal
https://gtacknowledge.extremenetworks.com/articles/How_To/Submit-RMA-via-New-Support-Portal
Regards,
Bin
Regards,
Bin
12-04-2017 03:00 PM
you can see the AP with apdiscover tool?
