WM3700 (WINGS 5.7.0.0-057R) We have a problem with the wireless controller.
jeon_min
New Contributor II
Good morning !
I did not speak English and I used Google Translator. Sorry.
Image WINGS 5.7.0.0-057R There is a failure. Please check the settings.
WM3700 is converted to Morotora image and is in use.The current version is using 5.7.0.0-057R.
There are many problems in operation.
1. Symptoms occur when you enable the firewall feature in a firewall policy.
2. The dhcp server is the current controller and the user does not receive the ip correctly.
Some people are good, but some people do not get IP from time to time.
3. I am running Active-Standby Controller and check the settings.
4. If the SNMP data is high, the response is late. I do not know why.
If the SNMP capacity is low, an immediate response is received. If the SNMP capacity is large, it is very late
Controller-A
! Configuration of RFS7000 version 5.7.0.0-057R
version 2.3
ip access-list BROADCAST-MULTICAST-CONTROL
permit tcp any any log rule-precedence 10
permit udp any eq 67 any eq dhcpc log rule-precedence 11
permit proto 254 any any log rule-precedence 19
deny udp any range 137 138 any range 137 138 log rule-precedence 21
deny ip any 224.0.0.0/4 log rule-precedence 22
deny ip any host 255.255.255.255 log rule-precedence 23
permit ip any any log rule-precedence 101
mac access-list PERMIT-ARP-AND-IPv4
permit any any type ip rule-precedence 10
permit any any type arp rule-precedence 20
ip snmp-access-list default
permit any
firewall-policy default
no ip dos smurf
no ip dos twinge
no ip dos invalid-protocol
no ip dos router-advt
ip dos router-solicit log-only log-level warnings
no ip dos option-route
no ip dos ascend
no ip dos chargen
no ip dos fraggle
no ip dos snork
no ip dos ftp-bounce
no ip dos tcp-intercept
no ip dos broadcast-multicast-icmp
no ip dos land
no ip dos tcp-xmas-scan
no ip dos tcp-null-scan
no ip dos winnuke
no ip dos tcp-fin-scan
no ip dos udp-short-hdr
no ip dos tcp-post-syn
no ip dos tcphdrfrag
no ip dos ip-ttl-zero
no ip dos ipspoof
no ip dos tcp-bad-sequence
no ip dos tcp-sequence-past-window
no ip tcp validate-rst-seq-number
no ip tcp validate-rst-ack-number
no ip tcp validate-icmp-unreachable
no ip tcp recreate-flow-on-out-of-state-syn
no ip tcp optimize-unnecessary-resends
ip-mac conflict log-only log-level warnings
dhcp-offer-convert
no proxy-arp
no firewall enable
no ipv6 firewall enable
no ipv6 strict-ext-hdr-check
no ipv6 unknown-options
no ipv6 duplicate-options
no ipv6 option strict-hao-opt-check
no ipv6 option strict-padding
no ipv6 dos multicast-icmpv6
no ipv6 dos hop-limit-zero
no ipv6 dos tcp-intercept-mobility
no alg ftp
no alg tftp
no alg dns
no alg pptp
virtual-defragmentation maximum-fragments-per-datagram 2000
no proxy-nd
no ipv6-mac conflict
no ipv6-mac routing conflict
mint-policy global-default
wlan-qos-policy default
qos trust dscp
qos trust wmm
radio-qos-policy default
no admission-control firewall-detected-traffic
no admission-control implicit-tspec
admission-control voice max-clients 256
admission-control voice max-roamed-clients 256
admission-control voice reserved-for-roam-percent 150
admission-control video max-clients 256
admission-control video max-roamed-clients 256
admission-control video reserved-for-roam-percent 150
accelerated-multicast max-client-streams 3
wlan guest_wifi
description guest@seoul
ssid guest@seoul
vlan-pool-member 90 limit 250
vlan-pool-member 91 limit 250
vlan-pool-member 92 limit 250
vlan-pool-member 93 limit 250
bridging-mode tunnel
encryption-type none
authentication-type none
wireless-client cred-cache-ageout 1200
wireless-client vlan-cache-ageout 1200
wlan guestSecure
description guestSecure@Seoul
ssid guestSecure@Seoul
vlan-pool-member 112 limit 250
vlan-pool-member 113 limit 250
vlan-pool-member 114 limit 250
vlan-pool-member 115 limit 250
wireless-client hold-time 5
dhcp-server-policy DHCP_Rule
dhcp-pool DHCP_114
network 210.104.114.0/24
address range 210.104.114.2 210.104.114.253
lease 0 4
default-router 210.104.114.254
dns-server 168.126.63.1
dhcp-pool DHCP_115
network 210.104.115.0/24
address range 210.104.115.2 210.104.115.253
lease 0 4
default-router 210.104.115.254
dhcp-pool DHCP_112
network 210.104.112.0/24
address range 210.104.112.2 210.104.112.253
lease 0 4
default-router 210.104.112.254
dhcp-pool DHCP_91
network 210.104.91.0/24
address range 210.104.91.2 210.104.91.253
lease 0 0 30
default-router 210.104.91.254
dhcp-pool DHCP_92
network 210.104.92.0/24
address range 210.104.92.2 210.104.92.253
lease 0 0 30
default-router 210.104.92.254
dhcp-pool DHCP_93
network 210.104.93.0/24
address range 210.104.93.2 210.104.93.253
lease 0 0 30
default-router 210.104.93.254
dhcp-pool DHCP_90
network 210.104.90.0/24
address range 210.104.90.2 210.104.90.253
lease 0 0 30
default-router 210.104.90.254
dhcp-pool DHCP_113
network 210.104.113.0/24
address range 210.104.113.2 210.104.113.253
lease 0 4
default-router 210.104.113.254
dns-server 168.126.63.1 164.124.101.2
dhcp-server activation-criteria cluster-master
management-policy default
telnet
no http server
https server
ssh
snmp-server manager v2
snmp-server community 0 hotelw ro
snmp-server user snmpoperator v3 encrypted des auth md5 0
snmp-server user snmptrap v3 encrypted des auth md5 0
snmp-server user snmpmanager v3 encrypted des auth md5 0
no t5 snmp-server enable server
no t5 snmp-server enable traps
banner motd welcome to CLI
l2tpv3 policy default
profile rfs7000 default-rfs7000
ip default-gateway 210.105.79.1
no ip default-gateway failover
autoinstall configuration
autoinstall firmware
crypto ikev1 policy ikev1-default
isakmp-proposal default encryption aes-256 group 2 hash sha
crypto ikev2 policy ikev2-default
crypto ipsec transform-set default esp-aes-256 esp-sha-hmac
crypto ikev1 remote-vpn
crypto ikev2 remote-vpn
crypto auto-ipsec-secure
crypto remote-vpn-client
interface me1
interface ge1
switchport mode trunk
switchport trunk native vlan 500
switchport trunk native tagged
switchport trunk allowed vlan 90-93,112-115,500,600
interface ge2
shutdown
interface ge3
shutdown
interface ge4
shutdown
interface pppoe1
use dhcp-server-policy DHCP_Rule
use firewall-policy default
cluster name Splex
cluster member ip 210.105.79.253 level 2
cluster member ip 210.105.79.254 level 2
cluster member vlan 500
cluster master-priority 255
cluster force-configured-state-delay 3
cluster radius-counter-db-sync-time 1
service pm sys-restart
router ospf
profile ap650 default-ap650
crypto load-management
interface radio1
wlan Seoul_WiFi bss 1 primary
interface radio2
interface ge1
interface vlan500
interface pppoe1
profile ap6562 DMW_AP_EXT_ap6562
ip default-gateway 210.105.80.1
no autoinstall configuration
no autoinstall firmware
device-upgrade auto ap6562
load-balancing balance-ap-loads
load-balancing balance-band-loads
load-balancing balance-channel-loads 5ghz
load-balancing balance-channel-loads 2.4ghz
interface radio1
interface radio2
antenna-mode 2x2
interface ge1
switchport mode access
switchport access vlan 600
interface vlan600
interface pppoe1
controller host 210.105.79.253 pool 1 level 1
controller host 210.105.79.254 pool 1 level 1
controller vlan 500
router ospf
rf-domain DMW
location DaeMinDongWiress
timezone Asia/Seoul
country-code kr
rf-domain JMW
location JeonMunDongWiress
timezone Asia/Seoul
country-code kr
rf-domain default
timezone Asia/Seoul
country-code kr
rfs7000
use profile default-rfs7000
use rf-domain default
hostname WM3700-MASTER
no use radius-server-policy
interface me1
duplex auto
ip address 192.168.0.1/24
interface ge1
no description
interface ge2
no description
switchport access vlan 1
interface vlan90
ip address 210.104.90.1/24
no dhcp-relay-incoming
interface vlan91
ip address 210.104.91.1/24
interface vlan92
ip address 210.104.92.1/24
interface vlan93
ip address 210.104.93.1/24
interface vlan112
ip address 210.104.112.1/24
interface vlan113
ip address 210.104.113.1/24
interface vlan114
ip address 210.104.114.1/24
interface vlan115
ip address 210.104.115.1/24
interface vlan500
ip address 210.105.79.254/24
interface vlan600
ip address 210.105.80.254/24
no use event-system-policy
cluster name Splex
cluster mode active
no cluster handle-stp
no cluster force-configured-state
cluster force-configured-state-delay 5
cluster radius-counter-db-sync-time 5
ip dhcp client hostname
ip dhcp client persistent-lease
logging on
logging console warnings
logging buffered warnings
ip routing
vrrp version 2
no controller adopted-devices external-devices
controller adopted-devices aps
rfs7000
hostname WM3700-SLAVE
interface me1
ip address 192.168.0.2/24
interface ge1
interface vlan90
interface vlan91
interface vlan92
interface vlan93
interface vlan112
interface vlan113
interface vlan114
interface vlan115
interface vlan500
ip address 210.105.79.253/24
interface vlan600
ip address 210.105.80.253/24
cluster name Splex
cluster mode standby
cluster master-priority 128
cluster handle-stp
logging on
ap650 00-04-96-5F-11-14
use profile JMW_Secure_ap4600
use rf-domain JMW
hostname SM_05F_5_5F1114
interface vlan500
ip address 210.105.79.211/24
ap650 00-04-96-5F-29-D0
use profile DMW_AP_ap4600
use rf-domain DMW
hostname SI_17F_2_5F29D0
interface vlan600
ip address 210.105.80.143/24
end
Controller-B
version 2.3
permit any
no ip dos smurf
no ip dos twinge
no ip dos ascend
no ip dos chargen
no ip dos fraggle
no ip dos snork
no ip dos land
no ip dos winnuke
no ip dos ipspoof
dhcp-offer-convert
no proxy-arp
no firewall enable
no alg ftp
no alg tftp
no alg dns
no alg pptp
no proxy-nd
qos trust dscp
qos trust wmm
wlan guest_wifi
ssid guest@seoul
wlan guestSecure
dhcp-pool DHCP_114
lease 0 4
dhcp-pool DHCP_115
lease 0 4
dhcp-pool DHCP_90
lease 0 0 30
dhcp-pool DHCP_91
lease 0 0 30
dhcp-pool DHCP_92
lease 0 0 30
dhcp-pool DHCP_93
lease 0 0 30
dhcp-pool DHCP_112
lease 0 4
dhcp-pool DHCP_113
lease 0 4
telnet
no http server
https server
no ftp
ssh
access all
snmp-server community 0 cityw ro
interface me1
interface ge1
interface ge2
shutdown
interface ge3
shutdown
interface ge4
shutdown
interface pppoe1
cluster name Splex
router ospf
profile ap650 DMW_AP_ap4600
interface radio1
interface radio2
interface ge1
interface vlan600
interface pppoe1
controller vlan 500
profile ap650 JMW_AP_ap4600
interface radio1
wireless-client tx-power 20
interface radio2
interface ge1
switchport access vlan 500
interface vlan500
interface pppoe1
controller vlan 500
profile ap650 JMW_Secure_ap4600
interface radio1
wlan Seoul_Wifi_Secure bss 1 primary
interface radio2
interface ge1
interface vlan500
interface pppoe1
controller vlan 500
interface radio1
interface radio2
interface ge1
interface vlan500
interface pppoe1
profile ap6521 default-ap6521
interface radio1
interface ge1
interface vlan1
ip address dhcp
ip address zeroconf secondary
ip dhcp client request options all
interface pppoe1
profile ap621 default-ap621
interface radio1
interface ge1
interface vlan1
ip address dhcp
profile ap6511 default-ap6511
interface radio1
interface up1
interface fe1
interface fe2
interface fe3
interface fe4
interface vlan1
ip address dhcp
interface pppoe1
interface radio1
interface radio2
4 REPLIES 4
Edmundo
New Contributor II
Hello
- Enable logs to debug mode
- Via CLI sh logging and send this information.
- Via CLI sh sh event-history and send information.
This Primary Controller Information
885175eb452a4fbca9e1b6293f496570_RackMultipart20171201-24987-1ufpa4g-Debug_inline.jpg
Regards
Edmundo
Drew_C
Valued Contributor III
Thanks. I'll make this public now.
jeon_min
New Contributor II
IP is not actually used, it is an arbitrary IP.
Drew_C
Hello Jeon,
Right now this topic is marked "private," which means only Extreme Networks employees can view and respond to it. Would it be okay if I mark this public so others can respond? I see some public IP addresses in your configuration, so I wanted to ask first.
