‎11-09-2018 12:29 PM
I have two AP-7522 access points. Both have version 5.9.1.4-004R. Both receive their power and network through a Symbol AP-PSBIAS-2P2-AFR "brick". I set the country name to "United States-us" on both because I read the radios will not turn on until you do.
AP#1 - This is the "host" access point connected to the wired LAN with access to the internet. The internal network is 192.168.1.0/24. I've given this AP the IP address 192.168.1.101. I configured a wireless network with SSID "myWireless", Secure-PSK, WPA2-CCMP, and the key is "myWirelessKey". Radio 1 is 2.4GHz, radio 2 is 5GHz.
AP#2 - This is the "client" access point that I want to bridge to AP#1. I have AP#2 connected to an unmanaged 5 port switch, which also connects a desktop PC. It's this desktop PC that needs access to the internet. I've given this AP the IP address 192.168.1.101. For the bridging configuration I followed the directions here (https://extremeportal.force.com/ExtrArticleDetail?an=000082884)
However when I run "show wireless bridge candidate-ap" it reports 0 candidate APs. AP#1 shows no wireless clients. The workstation can successfully ping AP#2 and vice versa. I am able to reach the web interface and ssh on AP#1 on the 192.168.1.0/24 network. But AP#1 can't ping AP#2 and vice versa. Nothing on the 192.168.1.0/24 network can ping AP#2 or the desktop PC. The desktop PC cannot reach anything on the 192.168.1.0/24 network.
Right now both APs are in the same room, 10 feet from each other, no physical obstacles between them.
In my searching I also found (https://extremeportal.force.com/ExtrArticleDetail?an=000063492) I tried the solution there but it didn't help.
Does anyone know what I'm doing wrong, or what I'm missing?
Additional questions:
1 - Do I have to configure any bridging properties on the AP#1 that is connected to the wired network with internet access? None of the guides I've read mention anything about configuration on the "host" AP, but since I can't get this working I'm wondering if some configuration is necessary on AP#1.
2 - Do I have to load a special firmware version to be able to access bridging configuration in the web GUI? Right now none of those configuration options are there and I have to do everything through ssh/command line. I know this was the case for some APs in the past that didn't have a web GUI at all and you had to download the firmware that included the GUI.
Thanks for any help you can provide!
Aaron
‎11-09-2018 02:06 PM
‎11-09-2018 01:55 PM
‎11-09-2018 01:04 PM
‎11-09-2018 12:57 PM
‎11-09-2018 12:44 PM
