AP-7522E does not take VC configuration and wireless networks doesn't work
Jorge
I configured an access point AP-7522E as a Virtual Controller with three vlan to use in three separate networks: one for corporate use that should connect to our existing LAN, another for employees and another for guests. Everything works very well when this AP is the only one in the network. As soon as I try to add a 2nd one to the pool, it doesn't take the vlans configured in the VC and no internet access is given. How to connect a second access point and configure it to an existing VC?
11 REPLIES 11
Andrew_Webster
New Contributor III
Have you verified that the VLANs are propagated throughout the wired switching infrastructure?
Christoph_S
The recommended way would be to have 3 vlans on your corp router to which the 3 vlans on the AP are mapped.
If you have only one corp vlan and 3 on the AP then Natting needs to be configured on the AP for this to work.
Here's a link to an article on same:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-Natting-on-a-WiNG-Express...
Regards
Christoph S.
