AP65XX aps timezone problem
Aviv_Kedem
Contributor
Hello community,
When I configuring any of AP65XX aps RF-domain#default#timezone Asia/Jerusarem and after sync running: show clock , I getting the UTC correct time instead of IDT.
When configuring the same config in to AP75XX aps - I getting the IDT correct time.
So there is some small annoying bug in the AP65XX family.
Regards,
Aviv
3 REPLIES 3
Aviv_Kedem
Contributor
Hello Ronald,
Thank you
Aviv
Ronald_Dvorak
Honored Contributor
You'd need to open a ticket with GTAC if you think that is a bug.
Aviv_Kedem
Contributor
Hello,
Any chance for firmware patch for this bug?
Thanks,
Aviv
