AP7532 Client Bridge Not connecting to host
Aaron_Becker
New Contributor II
I have 2 AP7532s and I'm trying to set up the 2nd to connect to an existing WiFi network. Ultimately, the 2nd 7532 would connect to a completely different WiFi network not associated with a 7532 (though it could be, I suppose).
The 2nd 7532 is not connecting to the original wifi network. I have Radio2 in bridge mode, with the SSID and PSK entered, but the radio does not show that it is connected and the host does not show the 2nd AP as a client. What critical step am I missing?
19 REPLIES 19
Aaron_Becker
New Contributor II
show wireless bridge candidate-ap 84-24-8D-A5-2E-10 Client Bridge Candidate APs: AP-MAC BAND CHANNEL SIGNAL(dbm) STATUS Total number of candidates displayed: 0 Total number of client bridges displayed: 1
ckelly
just for grins, run:
#show wireless bridge candidate-ap
Aaron_Becker
New Contributor II
The AP was default. I configured the ge1 port and a virtual interface to connect the wired port to the existing LAN for management purposes, configured NTP, and then eventually added a WLAN on radio1 to verify that radio was working and I could see its broadcast.
How can I get you the full config, or is that beyond the support of this forum?
ckelly
Okay. Not finding any bugs that relate to this that are known to exist in 5.9.1.0.
At this point, I'd need to see the full config to see if maybe there's something else configured that is causing this.
Is the AP otherwise default? (just have it configured to operate as a client-bridge and nothing else setup?
Aaron_Becker
New Contributor II
AP7532 version 5.9.1.2-006R
