AP7532 max clients reduced to 200
‎03-29-2020 01:40 PM
Hello guys,
For somewhat in WING 5.9.7 the max clients reduced from 256 to 200 for AP7532 with this message:
Exceeded max clients per radio 256/200 on the wlan XXXXX, supported on the platform ap7532
Not seen any notes in release notes.
It will be fixed back to 256 clients limit?
Thanks
Aviv
‎05-08-2020 02:00 PM
Hi Aviv,
AP7602/7632/7662 - 128 per radio, 256 per AP
Not sure about 3xx/4xx, 5xx is 256/500-capable.
Just to make sure - is there any particular use case behind this? The more clients on the same channel, the less throughput per client is going to be available due to airime saturation.
Hope that helps,
Tomasz
‎05-01-2020 03:20 PM
Hello Christoph,
I need to know the max clients count per radio/ap on these models:
Ap7602
AP7632/7662
AP3XX
AP4XX
Thanks,
Aviv
‎03-30-2020 07:11 PM
Hello Christoph,
Thank you for your reply, I’ll double check it.
Please share with us the very useful table with max client /radio/ap.
Thanks
Aviv
‎03-30-2020 04:48 PM
Hello Aviv,
You can have up to 200 wireless clients per radio and a max of 256 per AP:
I hope this helps,
Chris
