Auto-provisioning rule problem
‎12-08-2021 08:02 AM
I have a problem when I want to create an auto-provisioning rule.
First I created an AP profile for an AP305C.
I can see and select the earlier created profile from the profile name drop down menu.....
Then when I want to create an auto-provisioning rule and select the device type, I can't see the profile anymore in the profile name drop menu.
So, I can see and select the profile from the drop down menu when the device type is not selected first, but it disappears from the drop down menu when I select the device type.
What am I doing wrong?
3 REPLIES 3
‎12-09-2021 09:31 AM
Thanks for the quick response, as I am a terrible typist and make a lot of mistakes I will look into NOVA 😉
‎12-08-2021 01:20 PM
As Doug mentioned, use NOVA (HTML 5) interface from wireless controller to configure Extreme Universal Access Points (UAP). Otherwise, use CLI (Command Line Interface).
Thanks,
Chris Frazee
Thanks,
Chris Frazee
‎12-08-2021 01:04 PM
Hello,
NOVA UI is suggested when configuring UAP AP305C with WiNGOS. Please see this article for additional details: https://extremeportal.force.com/ExtrArticleDetail?an=000099949
