Captive Portal Options in WiNG 5.9.1
Saravanamurthy_
Contributor
In RFS 4000 OS Version is WiNG 5.9.1. Actually i want use captive portal. I seen Captive Portal Type 1. No Authentication Required. 2. Radius Authentication. 3. Registration. 4. Email Access. 5. Mobile Access. 6. Other Access. In these Six, which are used with out NAC Software? Explain.
13 REPLIES 13
Thanks, Anilash. I didn't realize we had an updated version of that guide.
BrandonC
The following WiNG 5.x Captive Portal guide goes through this process, including creating temporary guest accounts:
http://documentation.extremenetworks.com/ExtremeWireless/WING_5X_CAPTIVE_PORTALS_HTG_TME-12-2012-01_...
Edit: Anilash has linked a new, better document below.
Saravanamurthy_
Contributor
Hi Brandon,
How to configure Guest user will log from Captive Portal by OTP/Coupon generation automatically
BrandonC
Hi Sravanamurthy,
What other options are you looking for?
All captive portal options that require username/password login can be used with accounts local to the controller (by configuring the controller to act as a RADIUS server). A separate NAC device is not required.
Saravanamurthy_
Contributor
Hi, pls any one give me the solutions for above one
