Captive Portal Options in WiNG 5.9.1
Saravanamurthy_
Contributor
In RFS 4000 OS Version is WiNG 5.9.1. Actually i want use captive portal. I seen Captive Portal Type 1. No Authentication Required. 2. Radius Authentication. 3. Registration. 4. Email Access. 5. Mobile Access. 6. Other Access. In these Six, which are used with out NAC Software? Explain.
13 REPLIES 13
Hi Drew,
How to Configure Guest user will log from Captive Portal by OTP/Coupon generation automatically
Drew_C
Valued Contributor III
I've updated this topic's title to help others understand what you're looking for.
Saravanamurthy_
Contributor
Thanks. I need other options also...
Timo1
New Contributor II
you can use all without NAC.
Description you already write.
1. No authentication just a page to maybe accept T&C
2. Classical captive portal with RADIUS authentication (internal AAA is possible)
The other I normally don't use. Is more for self registration.
