I have VX9000 controller and extreme AP 7502, I have created 4 SSIDs(Students, Admin, Teachers, Guest)in the controller. I need to access the internet through created SSIDs.what are the steps needed to access the internet through created SSIDs?
Hi Niyas,
change the mode to trunk, configure the native vlan as the untagged vlan, configure the list of vlans that you want to allow, and after create the virtual interfaces for those vlans.
My controller is running in VMware platform, so the server has only one ethernet port. when I log in to controller interface showing ge1,ge2,xge1 etc.how to find out connected GE port and how to enable data VLAN in GE port.
Hi Niyas
the vlan creation on the controller is done the same way as on the APs the only difference is that you'll be modifying the Controller profile and no the AP Profile, don't forget to also add the vlan on you virtual environment.
you can look at the same link posted before for the Nat Configuration.
