Captive portal options in WiNG v5.9
Niyas
New Contributor III
I have VX9000 controller and extreme AP 7502, I have created 4 SSIDs(Students, Admin, Teachers, Guest)in the controller. I need to access the internet through created SSIDs.what are the steps needed to access the internet through created SSIDs?
Thanks
Niyas P
27 REPLIES 27
Nuno_Rocha
Hi Niyas,
change the mode to trunk, configure the native vlan as the untagged vlan, configure the list of vlans that you want to allow, and after create the virtual interfaces for those vlans.
Niyas
New Contributor III
Hi Nuno,
Please find the below screenshot,this is correct or not.my data VLAN is 18
f0d9066ae8194591bf0e241c5e548343_RackMultipart20180807-60589-ua8v6b-VX9000_GE1_inline.png
Thanks
Niyas P
Nuno_Rocha
Hi Niyas,
follow this link:
https://kb.vmware.com/s/article/1004252
Or create more ports on the VX.
Niyas
New Contributor III
Hi Nuno,
My controller is running in VMware platform, so the server has only one ethernet port. when I log in to controller interface showing ge1,ge2,xge1 etc.how to find out connected GE port and how to enable data VLAN in GE port.
Thank you
Nuno_Rocha
Hi Niyas
the vlan creation on the controller is done the same way as on the APs the only difference is that you'll be modifying the Controller profile and no the AP Profile, don't forget to also add the vlan on you virtual environment.
you can look at the same link posted before for the Nat Configuration.
