Connect Extreme Location?
Long_Tran
New Contributor III
Hi all,
I am testing ExtremeLocation.
But My AP (AP7522) can't connect to us.extremelocation.com although I followed the guide: ExtremeLocation Quick Start Guide.
Note: I opened port 443 in Modem/Router. But AP can't connect to extremelocation
Help me please.
Thanks
5 REPLIES 5
Slava_Dementyev
Hi, have you checked if the AP can resolve feeds-us.extremelocation.com?
Just try pinging this address from the AP itself.
which version are you running on the AP?
Thanks,
Slava
What should I do next?
And I use nslookup feeds-us.extremelocation.com for result:
" Non-authoritative answer:
Addresses: 18.195.156.163
35.156.143.49
52.28.164.123
Aliases: feeds-us.extremelocation.com "
And I ping to 18.195.156.163; 35.156.143.49; 52.28.164.123. But can't.
How to fix it?
Thanks
Hi Dementyey,
Test result.
ap7522-19F630#ping feeds-us.extremelocation.com
PING lsense-elb-classic-prod-705677272.eu-central-1.elb.amazonaws.co (18.195.156.163) 100(128) bytes of data.
--- lsense-elb-classic-prod-705677272.eu-central-1.elb.amazonaws.co ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 4036ms
1. SSH to the AP
2. Ping feeds-us.extremelocation.com
