WiNG AP 7522 is not managing with WiNG VX9000 controller?
‎04-21-2018 09:44 AM
I am unable to manage the WiNG AP7522 to WiNG VX9000 controller, I have checked the firmware version of AP and Controller even though both are having the same firmware AP is not adopting with WiNG vx900 controller
Firmware:AP7522 & VX9000 version 5.9.0.0-033R
6 REPLIES 6
‎04-22-2018 07:49 AM
The VX9000 is supplied into downloadable image images
image 1) VX9000-5.9.1.4-004R.img
This is the full image contains all software images for all support access point
image 2)VX9000-LEAN-5.9.1.4-004R.img
The lean image has had the AP software images removed to reduce the size of the software build
To confirm the software images installed
please use the following command
show device-image versions
This will list all software versions installed
AP's will also adopt even if the there is a software mismatch.
show adoption status
will tell you if the aps have been adopted, if there is a software mismatch this will show here.
Finally, the VX9000 does not automatically update the firmware
to manually update firmware please use
device-upgrade all
device-upgrade all
‎04-22-2018 05:03 AM
See if the AP7522 firmware is also uploaded on the VX. Some customer mine has that same issue... the firmare is not by default on the VX.
‎04-21-2018 01:34 PM
Try setting the controller host on the AP, here are CLI commands :
AP#self
AP(config-device )#controller host xx.xx.xx.xx
AP(config-device )#commit write
AP#self
‎04-21-2018 01:28 PM
Are you sure that the AP7522 is not 'Express' version AP? Can you provide a full part number of the AP7522, you can get that via cli command ' sh version'
