controller assisted mobility will help ?
‎07-21-2017 04:23 PM
We have in some warehouse, is divided with 2 ip segments.We have here only unmanaged switches, with 20 pices of AP6532 and 20-25 wireless clients.
We need to make wireless clients to roam between 2 ip segments.
If we configure VC with controller assisted mobility + layer3 adoption, it will make the roaming work?
Or just only way is buy NX/VX for tunneling WLAN traffic to controller ?
Thanks
Thanks
11 REPLIES 11
‎07-21-2017 04:53 PM
Thank you
‎07-21-2017 04:38 PM
Hello Aviv,
In a VC environment, if all APs are in the same broadcast domain (layer 2) roaming will be seamless.
As of today, If some APs are behind a routed switch (layer 3 adoption) then roaming between APs on either side of the switch will not be seamless unless a fully fledged controller (NX/VX) is used.
Regards,
Chris
Regards,
Chris
Christoph S.
