ā12-15-2023 01:07 PM
Hello community,
I'm trying to configure AP410i to disconnect clients that falls below -75db, but in wireless configuration I cannot find any settings related to minimum signal strength, signal threshold or similar.
Can anybody point me in the correct direction to configure this.
Thank you in advance for your help.
Alex
Solved! Go to Solution.
ā12-18-2023 08:11 AM
Hello Jan,
Thanks to your help I was able to find the command on the CLI manual to fiddle with this.
I'll do my test to find my optimal values.
Thank you,
- Alex
ā12-18-2023 03:18 AM
You can suppress probe responses based on RSSI thresholds, but not deauthenticate/disassociate clients programmatically.
What's the Minimum Basic Rate of the SSID? You could work on the MBR.
Hello Jan,
Thank you,
- Alex
