Extreme AP7502 firmware upgrading issue
Niyas
New Contributor III
I have Extreme access point AP7502, I have upgraded the firmware of AP to 5.9.1.0-029R. After upgrading firmware when I try to login AP through GUI showing error 404 not found.
7 REPLIES 7
Niyas
New Contributor III
Hi Ronald,
my AP IP https://169.254.21.122
where i put this WiNG error 404 ?
Ronald_Dvorak
Honored Contributor
What I mean is that you've a search function on this forum webpage for knowledge base articles and other available information.
It's in the upper right corner of this/the TheHub portal
If you search for "wing error 404" the first article in the results gives you the answer to the issue = you've installed the LEAN image instead of the full image.
Ronald_Dvorak
Honored Contributor
If you put "WiNG error 404" in the search = upper right corner you get this.
https://gtacknowledge.extremenetworks.com/articles/Q_A/Why-I-am-unable-to-log-into-newly-bought-AP75...
