01-27-2026 04:57 AM
I feel that the antennas, like the 510i, are kind of a hacky solution from Extreme, especially considering they still use a Flash Player interface in 2026. It’s not exactly a problem or a complaint, but it’s bizarre to see this still being used. Extreme does have a management software for WiNG, but even so, they didn’t bother to put at least an HTML5 interface on the antenna itself.
Solved! Go to Solution.
01-27-2026 05:18 AM
01-27-2026 05:28 AM
The WiNG OS was released in 2010. At that time, Flash was state-of-the-art.
To change of the UI for each WiNG Access Points is very expensive.
But as WiNG was designed and developed for controller based environments, there is a HTML5 based UI available on the controller, called NOVA.
Please find a reference here: https://documentation.extremenetworks.com/WiNG/7.9.1.0/WiNG_7.9.1.0_GettingStartedGuide_NOVA.pdf
01-27-2026 05:28 AM
01-27-2026 05:18 AM
concordo.
