Extreme Wing Management Base Interface of Auto-Elected Virtual Controller
blu3nood
Dear Support
Inside the Extreme Wing AP Virtual Controller setting that have 1 setting call Management Base Interface of Auto-Elected Virtual Controller and what IP I should insert. Can any expert help explain on this features settings I totally not understand what IP I should insert.
3 REPLIES 3
blu3nood
Dear Support
That 2 options to configure the AP to become VC which article I should follow
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-create-Virtual-Controller-redundancy
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-turn-a-WiNG-AP-into-a-virtual-controller
Best Regards
Goh Chee Wong
blu3nood
Dear Support
Based on my understanding
Management Base Interface of Auto-Elected Virtual Controller is need to insert the same segment virtual IP address then once the AP elected as VC it will hold the virtual IP. Correct me if I wrong
Best Regards
Goh Chee Wong
RobertZ
VC can be elected automatically based on rf-domain manager selection process (lowest MiNT-ID or highest model). Once Virtual Controller is elected it will install virtual management IP address as secondary address and send GARP update to the network.
How To: How to create Virtual Controller redundancy?
