Extreme Wireless vs HParuba selling point required
muthu_naganatha
Hi Team,
This is muthu I am the extreme wireless engineer I need selling point Extreme wireless.
Extreme Vs Hp Aruba
Regards
N.Muthu
9 REPLIES 9
Rajesh_Jeevendr
Hi
The equivalent of Aruba Instant AP is Wing Express AP, not the wing AP ?
Was the above discussed in that perspective ?
Please correct me if I am wrong.
Regards
Rajesh J
from the feature set I wouldn't use the Express one. Mostly this solution have enough features, but you can't extend it. The Instant APs have maybe comparable features, but you can extend it with AirWave or a controller and a firmware update. This is with the Express not possible.
Best regards,
Timo
muthu_naganatha
Thanks very much ....
Timo1
New Contributor II
Hi, Captive portal is very powerful compared to Aruba. Remote debug functions are very powerful with the WiNG and not possible with Aruba. This are the two best functions compared to aruba. The VC from Aruba Instant is better at the time. I wasn't use the VC from WiNG, use a VX9000. For configuration WiNG provide more options, if you know what you'll do. Aruba and a lot other vendors are limited in the options. Best regards Timo
