‎08-07-2021 02:36 AM
Hi you
I am using AP 7161, 7562 and controller RFS4010 with license for 16 AP. I plan to add new AP 7562, however supplier informed that new generation AP7562 will have wifi 6 and it cannot be added to RFS4010 controller.
So how should my system be able to upgrade or replace the old APs with newer ones?
I upgraded the Controller for 1.5 years and I reported to my boss that it will add new Aps later on.
Solved! Go to Solution.
‎08-18-2021 12:14 AM
WiNG added heterogenous virtual controllers quite a while ago. The AP460 can be a virtual controller for the following APs: AP460, AP410, AP360, AP310, AP8533, AP8432, AP7662, AP7632, AP7612, AP7562, AP7532, AP7522.
Here is a link to the article: https://extremeportal.force.com/ExtrArticleDetail?an=000089448
‎08-07-2021 03:47 PM
Tuan,
11ax WiNG OS APs, like the 360,460, and 560 models, require WiNG-7 firmware, but the RFS4010 is not supported by WiNG-7.
So in order to use the 11ax WiNG APs mentioned, you would need to upgrade the controller to a model that supports WiNG-7 - the closest matching hardware model would be the NX5500.
Or you could go with a VM solution (VX9000). The VX9000 is half the list price of the NX5500 and comes with 64 AP licenses built-in.
In either case, you could transfer your existing licenses from the RFS4010 to the new controller and would have the ability to run all new WiNG model APs.
