I need document of Ldap configuration in AP7532
‎10-07-2017 03:43 AM
I need document of Ldap configuration in AP7532?
5 REPLIES 5
‎10-09-2017 06:41 AM
Hi Saravanamurthy,
"old but gold" document Active Directory Authentication - HOW TO GUIDE can be found under this Portal page
Nothing much changed in matter of LDAP / AAA integration, so more-or-less everything should be still valid.
Regards,
Ondrej
Regards,
Ondrej
‎10-09-2017 05:13 AM
I'll recommend to use a Windows Server with NPS. It's a better solution and for "free". You can easy install the NPS on a running Windows Server.
‎10-07-2017 11:56 PM
Thanks
‎10-07-2017 12:19 PM
Try the below, it's for different AP but still applies:
How to configure a Summit WM3000 for 802.1x authentication with internal RADIUS, using LDAP to conne...
