Mismatch between the controller and AP firmware versions
‎08-29-2018 11:15 AM
I have extreme wing controller VX9000 and access point AP7502.i have configured SSIDs and mapped to Radios, but still broadcasting is not getting. Both controller and AP running with different versions.
controller version= 5.9.1.0-029R
Access point version=5.8.4.0-034R
Thank you
Niyas P
Thank you
Niyas P
18 REPLIES 18
‎08-29-2018 11:22 AM
Hi Christoph,
How to upgrade firmware version of AP through GUI or CLI?
Thanks
Niyas P
Thanks
Niyas P
Now broadcasting success,but internet is not getting.
Thank you
Niyas P
Thank you
Niyas P
Thanks for your valuable support
In this case you might want to consider placing them all (including the controller) on the latest code. You can find it on our support portal.
as previously mentioned, 3cdaemon is a good tool to use.
B: If you need GUI access to the AP follow these steps:
#self
#no device-upgrade auto
#com wr ap7502
#device-upgrade auto
#com wrIf you still require assistance, please contact GTAC.
- Install on your computer
- If using tftp, disable all firewalls on said computer
- Place the .img (not lean) into the root directory of the tftp server
- Prevent APs from automatically upgrading since the AP image on VX is LEAN. Instructions in the recommended upgrade doc
#self
#com wr
- Upgrade the controller. Instruction previously provided.
- load the AP image - downloaded earlier - into controller. Instruction previously provided.
- Upgrade the APs by rf-domain. Instructions in recommended upgrade doc
- If you would like new APs added later on to automatically upgrade, remove the no device-upgrade auto command
Christoph S.
yes,new deployment of vx9000 and access point 7502.i have already adopted AP to controller and configured SSIDs and also mapped to Radios.but still broadcasting is not getting.i have no FTP and TFTP servers.we are running with DHCP platform.
Thank you
Niyas
Thank you
Niyas
