OIDs for RF Quality Index
Max_McGrath
New Contributor III
Hello -
I'd like to track the RF Quality Index of my entire WiNG (VX9000) system and the same index per each RF Domain. Is there an OID in the WiNG MIBs for this?
Thanks!
3 REPLIES 3
Andrew_Blomley
I would recommend testing NSight, it is what the NSight was designed for.
https://documentation.extremenetworks.com/WiNG/5.9.0/9035124_NSight_5_9_UG.pdf
Max_McGrath
New Contributor III
Thank you.
That brought back an index per client. But what I'm really looking to keep track of (for history/trending purposes) is the over RF Quality Index of either the entire system or on a per RF Domain basis....much like below. A single digit score per RF Domain.
87dee861be4c45a18fb65a6008060d89_RackMultipart20180414-63613-1r00pln-index_inline.png
Thanks!
RobertZ
I found these:
-- 1.3.6.1.4.1.388.50.1.4.3.2.6.1.1.19
wingStatsRfdWlClientStatDetailQIndex OBJECT-TYPE
SYNTAX Integer32
MAX-ACCESS read-only
STATUS current
DESCRIPTION
"RF quality Index
Measure the quality of the medium in percentage. It is a function of average retries and error rate. Its range is from 0-100. Typically:
-1: no data available ( e.g. radio is not in wlan operation mode )
0-20: very poor quality
20-40: poor quality
40-60: average quality
60-100: good quality
XPath: /wing-stats/rf_domain[name=key1]/wireless/client-stats-details[mac=key2]/q_index"
::= { wingStatsRfdWlClientStatDetailEntry 19 }
-- 1.3.6.1.4.1.388.50.1.4.3.2.5.1.1.20
wingStatsRfdWlClientStatQIndex OBJECT-TYPE
SYNTAX Integer32
STATUS current
DESCRIPTION
"RF quality Index
20-40: poor quality
XPath: /wing-stats/rf_domain[name=key1]/wireless/client-stats[mac=key2]/q_index"
::= { wingStatsRfdWlClientStatEntry 20 }
-- 1.3.6.1.4.1.388.50.1.4.2.25.10.1.1.21
wingStatsDevWlRadioStatQIndex OBJECT-TYPE
SYNTAX Integer32
STATUS current
DESCRIPTION
"RF quality Index
20-40: poor quality
XPath: /wing-stats/device[mac=key1]/wireless/radio-stats[radio_id=key2]/q_index"
::= { wingStatsDevWlRadioStatEntry 21 }
-- 1.3.6.1.4.1.388.50.1.4.3.2.9.1.1.21
wingStatsRfdWlRadioStatQIndex OBJECT-TYPE
SYNTAX Integer32
STATUS current
DESCRIPTION
"RF quality Index
20-40: poor quality
XPath: /wing-stats/rf_domain[name=key1]/wireless/radio-stats[radio_id=key2]/q_index"
::= { wingStatsRfdWlRadioStatEntry 21 }
