‎06-11-2020 01:35 PM
Hello,
I am trying to connect to the controller (RFS-4010) and AP 7562 using a console cable. The cable was make independently, the scheme was found on the Internet (in the attachment). But I can't connect via the console port. In attach I insert one screen on my computer.
Please help me, maybe my scheme pinout console cable is wrong?
I use application Putty
serial port setting:
‎06-15-2020 06:24 AM
Tell me, what is the error? As far as I can see, we have the same Pinout with you.
‎06-12-2020 12:59 PM
I think you have the pinout wrong it should be as below:
Pinout: RJ45 - DB9F
