Power AP310 WING 7.4.1.1-001R
tcheurby
New Contributor III
Hello,
I have the impression that there are still power problems on the latest firmware version. The AP310 indicates a maximum power of 2.4 GHZ at 32 mW and 50mW at 5 Ghz for the country code fr.
Strangely if I look at an AP7522 with the same firmware version the result for the AP310 is different... an idea ?
I would like to sell AP3xx but I'm still afraid.
ap310-752888#show wireless regulatory device-type ap310i fr
  #  Channel Set Power(mW) Power (dBm) Placement      DFS          CAC(mins)
  1   1-13        32        15          Indoor    Not Required   0
  2   36-48       50        17          Indoor    Not Required   0
  3   52-64       50        17          Indoor    Required       1
  4   100-116     80        19          Indoor    Required       1
  5   120-128     80        19          Indoor    Required       1
  6   132-140     80        19          Indoor    Required       1
ap310-752888#show version
AP310 version 7.4.1.1-001R
Copyright (c) 2004-2019 Extreme Networks, Inc. All rights reserved.
Booted from primary
ap310-752888 uptime is 0 days, 00 hours 09 minutes
CPU is ARMv7 Processor rev 5 (v7l), No. of CPUs 4
Base ethernet MAC address is 20-9E-F7-75-28-88
System serial number is 2022Y-16161
Model number is AP310i-WR
ap310-752888#
ap310-752888#show wireless radio
RADIO                RADIO-MAC             RF-MODE        STATE                  CHANNEL    POWER #CLIENT
ap310-752888:R1      20-9E-F7-54-D5-00 2.4GHz-wlan           On               11 (  smt) 12 ( 30)       0
ap310-752888:R2      20-9E-F7-54-D5-10   5GHz-wlan           On              44w (  smt) 14 ( 30)       1
Total number of radios displayed: 2
ap7522-02FE30>show wireless regulatory device-type ap310i fr
  1   1-13        100       20          Indoor/Outdoor   NA             NA
  2   36-48       200       23          Indoor           Not Required   0
ap7522-02FE30>en
ap7522-02FE30#show version
AP7522 version 7.4.1.1-001R
Booted from secondary
ap7522-02FE30 uptime is 0 days, 07 hours 44 minutes
CPU is ARMv7, No. of CPUs 2
Base ethernet MAC address is 74-67-F7-02-FE-30
System serial number is 15316522204621
Model number is AP-7522-67030-EU
ap7522-02FE30#
1 ACCEPTED SOLUTION
tcheurby
New Contributor III
Hello,
Thanks to Marek from GTAC support for the explanations.
I must admit it is not too intuitive and it is confusing. Let me explain whole math behind.
The visible number in a CLI (i.e. show wireless radio) is a value before adding antenna gain, chain gain and possible MIMO gain. So basically a value leaving a chipset. All those things together (final radio transmition power) then cannot exceed maximum allowed power per regulations (20dBm).
So correct math in this case is like this:
12dBm visible output + 3dBm chain gain (radio is by default 2x2, so gain is 3dBm) + 5dBm antenna gain = 20dBm per maximum allowed by regulations. Meaning you cannot get over 12dBm visible output in 'show wireless radio', when using 2x2.
Regulatory table for AP310i is showing max 15dBm, which is a value for 1x1 radio. In case of using 2x2 (two chains used by default) are both radios using 12dBm per chain power and the final power is 15dBm. It is a reason, why regulatory table is showing 15 and why you see in CLI 12.
There was also the explanation in the last powerhour available on the dojo :
show wireless regulatory device-type APxxx country-id” command
For the legacy APs
This command basically showing the information of the legacy CFT table (Channel Frequency Table).  The CFT table doesn’t have the information of “tx-chain numbers”, “antenna-type”, “antenna-gain” information, it only has the max EIRP power for each country/channel/placement/TPC combination.
For Extreme APs
The WiFi 6 APs (3xx/4xx/5xx) don’t use the legacy CFT table anymore, so the power/channel information is derived from the “Extreme Regulatory power table” which clearly defined the power values for each country/antenna-type/antenna-gain/channel/placement combination.
If the AP is an external antenna SKU, user will also need to give the antenna-type at the end of the command, eg “show wireless regulatory device-type AP3xx us ml-2452-apa2-01”
EIRP CALCULATION = TX Power + Antenna Gain + MIMO (Gain)
MIMO GAIN = 10*log(#of chains)
Regards,
11 REPLIES 11
tcheurby
New Contributor III
Hi Jonathan,
Thank you for the information, it is indeed very worrying. I haven't yet done a real test with an Ekahau for example.
If you ever install this in a warehouse it can be very problematic I guess…
I don't know where we're going but I'm worried. AP WIFI 6 has been on the market for a long time now and there are still a lot of surprises to be discovered... And all the old APs are very soon EOS and it seems to me that it is difficult to get some of them
If tomorrow I get an order for 50 AP for a warehouse I would be very annoyed... It's nice CloudIQ but if the signal doesn't reach the picker the pallet won't leave. Sometimes it seems that Extreme doesn't realize the impact on a production and the cost with such a bug.
If you have news from the GTAC, I'm very interested 🙂
Regards,
JonathanM
ok, thanks for the explanation!
Nevertheless we measured the signal strength of the AP310i and also of AP3705/AP3935 in an installed base. With the AP310i we have around 10dB less signal at the same place.
But we discussing the issues at the moment with the GTAC so will see what they can find out!
Regards,
J.
tcheurby
New Contributor III
Hello,
For the legacy APs
For Extreme APs
Regards,
SamPirok
Community Manager
Thank you for letting me know, and for providing your case number. I will reach out to the team that is managing your case to see what we can do to move the case forward. I haven’t heard of a fix yet, but that is something we’ll want to confirm via your case to be sure.
