Problem connecting notebooks with AES
‎06-15-2018 06:00 PM
I have tried to configure the wireless controller with only WPA2 / AES but I only have two options, (WPA / WPA-TKIP and WPA2-CCMP), the second option is neither TKIP nor AES, I need to configure AES on all notebooks. The Wireless Controller is Model WIRELESS MOBILITY v5.4, it is an old model but it is operative. This is a LOG that shows my controller via CLI:
WLAN: WLAN001 (ssid: WLAN $ 001)
ACCESS-POINT: Name: SWCOFP15_p39 Location: default
RADIO-ID: 00-04-96-88-A7-7C: R2, alias SWCOFP15_p39: R2
RADIO-NAME: radio2 Bss: 00-04-96-8A-44-22
STATE: Data-Ready
CLIENT-INFO: 802.11a, vendor: E4-A4-71
SECURITY: Authentication: eap Encryption: tkip
Do you think it is a limitation of the hardware? I would appreciate your support.
THKS,
AXEL OSORIO
STATE: Data-Ready
THKS,
AXEL OSORIO
4 REPLIES 4
‎06-15-2018 06:33 PM
WPA2/CCMP is what you need to configure for AES.
Currently I am sending automatic configuration through GPO from Active Directory and I only have the options "TKIP" and "AES-CCMP", we made the change in the GPO by removing TKIP and changing it by AES-CCMP, in the controller as well, but the laptop can't connect.
If the wireless clients all support WPA2/CCMP (AES), then yes, disable the WPA/WPA2-TKIP.
only WPA2 / CCMP?, So, should I remove the check in WPA / WPA2-TKIP?
