Radio Settings - Transmit Power
Daniel_Valera1
New Contributor II
Hello,
I need change the Transmit Power configuration in the 2,4 ghz radio only in 1 AP of all wireless domain
Actuality the transmit power profile configured is in SMART (0 to -20 dbm)... i want change static mode in one only ap maybe in -25 dbm... my questions is: if i change it don“t affect the signal of others AP?
12 REPLIES 12
Colin_Steadman
I'm interested in your comment about putting stain on the broadcast module if its set to -25dbm. What causes the shorter life? Could you elaborate? Thanks.
Daniel_Valera1
New Contributor II
Thanks.... clarify my question
Regards
Don1
You can change the power level by selecting the AP from the parent controller and configuring the power per radio. As far as signal goes; depending on the power setting, you could get channel overlap or the power of that particular AP may interfere with connecting to any existing APs in the same area as the result of being overly powered. I never recommend -25dBm due to the strain it puts on the broadcast module and that it will definitely shorten the life span of the AP.
