RFS6000 SNMP OID for Area/Build does not work
valmison
I downloaded WiNG-MIB and I was able to locate many OIDs I was looking for, but the OID "1.3.6.1.4.1.388.50.1.3.18.1.1.4" or "1.3.6.1.4.1.388.50.1.3.34.1.1.4" should display the Area / Build information of the controller or AP does not work. I already ran a full snmpwalk and could not find any other OIDs that display the information.
The RFS6000 controller is running WiNG v5.4 with firmware 5.4.1.0-020R.
4 REPLIES 4
vanelm
Contributor
5.9.1.(5) is the latest one for RFS6000
valmison
Thanks for the guidance.
Could you tell me where I can get the firmware to download?
Andrew_Blomley
I would recommend that you upgrade to a later version of the code. 5.4.1.0-020R we are currently on 5.9.3. you will need a support contract to access this software code.
