VX9000 and wireless in tunnel mode
Jose_LV
New Contributor III
Hi everybody
A quick question:
The VX9000 controller allows wireless in tunnel mode?
Thanks.
Regards
1 ACCEPTED SOLUTION
Raul_Carbonari
Contributor
No...
Does VX9000 platform supports tunneling?
https://extremeportal.force.com/ExtrArticleDetail?n=000017106
4 REPLIES 4
Jose_LV
New Contributor III
ok. tanks for the clarification.
RobertZ
No, you can not tunnel traffic to VX9000 as this is a virtual platform and this is not supported.
Terry_Yang
New Contributor III
Hi Sirs
almost NX series will be EOS , but Wing has a new controller CX9000
I want to know CX9000 support tunnel mode ?
I personally believe that the CX9000 probably doesn't support tunnel mode because the CX9000 is still using a container to encapsulate the VX9000
Raul_Carbonari
Contributor
No...
