VX9000 total wireless LANs ?
Vimalraj_Veerab
New Contributor III
Hi guys,
Bonjour,
Please help me that, in VX9000 total of how many WLANs can able to add .?
14 REPLIES 14
Christoph_S
Hello Vimalraj,
If you're asking about the scalability of the VX9000 then the total number of WLANs/device would be 1022 taking into consideration the min hardware resources that should be allocated:
3 x VCPUs @ 2.4GHz
5GB RAM
5GB HDD
Christoph S.
Shay_Weir
New Contributor II
From a management perspective, no more than 6 WLANs. This will keep the beacons down to a low roar for better performance.
Thanks for your clear clarification Shay Weir.
If I'm using 9 SSID which all are in hidden mode on same access Point over a corporate setup total of 53 Access points I'm using it.
It will cause any impact. If yes means please help me to sort it out.
FYI.
Access Point model :- AP7532
Controller :-- VX9000
Shay_Weir
New Contributor II
Yes. You can have many WLANs configured. The limitation of 6 is on the AP side itself. There is the confusion. Controller wise the numbers are as has been stated for the WLANs. Just do not put more than 6 on each AP. If you can standardize across your environment, that will hep with making changes in the future. Change one, they all change. You can also use wlan-overrides to customize each location.
Hope this helps to clarify the limit of 6 WLANs - per/AP not controller.
Hi Shay,
I'm using the same for different locations all-round India more than 150+ now. Would wants to know that for VX9000 what is maximum capacity we may add.
Likewise RFS4000 has only limited of 256WLANs.
Please help me,
