Wing 7.9.1.0 Known issue WOS-4976 (channel width radio 1)
‎06-22-2023 08:25 AM
Hello,
it is not written in the release notes of Wing 7.9.1.0 and 7.9.0.1, but it seems that known issue:
WOS-4976 Channel-width assignment for 11ax APs is not happening based on channel-width
configured in smart-RF policy on Radio 1
is still in Wing 7.9.x.y
I have a VX9000/AP310 installation where the AP310 always select 40 MHz bandwidth on radio 1, which is set to 2.4 GHz, which doesn't make any sense. Only way to set 20 MHz channel width is either to set static channel or to set it to random. on settings ACS or SMART-RF it always uses 40 MHz. In smart-rf is of course channel-with 2.4 GHZ 20 MHz (the default) and channel list 1,5,9,13, as also set in the RF-domain.
Martin
‎06-26-2023 05:58 AM
unfortunatly it seems it is not solved, or there is a new issue with 7.9.1.0-022R and combination VX9000/AP310
‎06-27-2023 05:31 AM
Pls contact GTAC. There is also 7.9.2 engineering fw for those and other issues available.
‎06-23-2023 05:33 AM
Channel width issue should be solved in WiNG 7.9.1.0-022R
