08-25-2021 09:06 PM
Some access points within a RF Domain won’t update their hostnames unless I do so logging in through SSH remotely. It only happens on some APs I got. I didn’t set up the config and will document myself a bit on how to initially configure a RF Domain for clues, but meanwhile it could have happened to someone else already so I’m putting it up here in case anyone has or had the same issue.
Solved! Go to Solution.
08-25-2021 09:55 PM
Appreciated and due to the AP/VX being on different firmware, this is expected. No configuration pushes from VX9 to adopted APs will occur until firmware is matching.
The following is a Knowledgebase Article explaining:
https://extremeportal.force.com/ExtrArticleDetail?an=000085427&q=wing%20version%20mismatch
08-25-2021 10:22 PM
Perfect! Thank you for your help.
08-25-2021 10:04 PM
From the VX CLI (Command Line Interface), enter the following:
enable [enter]
show adoption status [enter]
If using the UI via VX
Statistics > Rf-domain VX is in > Highlight VX > Adoption > Adopted Devices and look under “Status”
08-25-2021 10:00 PM
Thanks for the info, I just connected the dots a few minutes ago and found this post as well:
Mismatch between the controller and AP firmware versions | Extreme Networks Support Community
I’ll see about updating our firmware on applicable APs, thank you.
One question though: how could I see a log for the version mismatch as pointed in the document URL you linked? Should I enable logging at the VX9000 and then see the logs in the WiNG tool?
Could you please point me to a document on how to enable logging without breaking my VX9000? I fear that if done incorrectly I may saturate the device and become unmanageable without a reboot or something.
08-25-2021 09:55 PM
