Wireless Bridge ( AP7532 to AP7532 )
Phil_storey
Contributor
I have two AP7532 setup as a wireless bridge, The bridge is working, On the remote side I have installed an ap7131 - I can see the SSID and connect units will get an IP, however the AP is not checking into the RFS7000, If I connect the AP to the local network it does check in
On the AP I have 3 SSID's 1 on vlan1 ( same as the RFS7k ) and 2 on Vlan 10 which leaves the network via a different route.
I can connect to the SSID on VLAN1 and get an IP, the two wifi networks on VLAN 10 are not operational at present as I have to add the VLAN info to the network switch where the AP is
Have I missed something when setting the bridge up ?
21 REPLIES 21
Hi Steve,
where on the AP 7131 ?
Timo1
New Contributor II
Do you use local bridging for traffic? If yes, are booth VLANs added to the bridge?
