WLAN (Identify / Wing) something similiar to LAN 802.1x quiet period ?
M_Nees
Contributor III
On 802.1x LAN port i can configure "dot1x quiet period" if i have trouble with rejected clients which try it on and on and on ...
529748869294494e8869734ae1079bd1_RackMultipart20180227-123572-1qm0f7f-LAN-quiet-period_inline.png
Because i have some of these issue with clients in my WLAN SSID i want to configure that on Identifi WLAN. Unfortunately i found nothing. Do i oversee something ?!
Do WING Wireless provide this ?
(Aruba seems to provide this feature)
3 REPLIES 3
M_Nees
Contributor III
OK - that sound good - WING is able to configure that!
But what about the Identifi solution ?
(Current customers environment is Identifi)
M_Nees
Contributor III
Feature seems to be available in next version 10.51.
Ondrej_Lepa
Hello M.Nees,
If I understood the request correctly you might use following:
VX# configure
VX config)# profile
VX(config-profile-default-ap7532)# dot1x holdtime <0s-600s>Adding a "holdtime" provides time for the network to converge before
receiving or transmitting 802.1x authentication packets.
Regards,
Ondrej
