Display individual stacked SecureStack Switch / Firmware Status
FAQ_User
Article ID: 5455
Products
SecureStack C3
SecureStack C2
Matrix C2
SecureStack B3
SecureStack B2
SecureStack A2
Commands
'dir'
'show version'
'show switch'
Goals
Display individual stacked switch status
Determine firmware version for each stacked switch
Solution
On the SecureStack C3/B3/B2/A2, and with SecureStack C2 firmware version 2.01.37 and higher, dual firmware images are supported. The 'dir' command reflects this by displaying both the currently selected image and the older image to be overwritten upon the next firmware download operation, for the master unit only.
A 'show version' and/or a 'show switch' command will both show currently selected firmware information for all units of a SecureStack standalone/stack.
Matrix C2(ro)->dir [C2 firmware 2.01.24 and lower]
Files: Size
configs:
johnm2.cfg 3173
testc2.cfg 3173
johnm.cfg 56421
logs:
current.log 10001
Matrix C2(ro)->dir [C3/B3/B2/A2; and C2 firmware 2.01.37 and higher]
Images:
Filename: c2-series_03.01.20
Version: 03.01.20
Date: Fri Jun 3 10:37:06 2005
CheckSum: 35df004873035b50b0dc77f843d52af8
Compatibility: C2G124-24, C2G124-48, C2H124-48, C2G124-48P, C2H124-48P
C2K122-24, C2G170-24, C2G134-24P
Filename: c2-series_03.01.45 (Active) (Boot)
Version: 03.01.45
Date: Wed Jun 29 11:09:22 2005
CheckSum: f44f9bf9a41ae24d10862024ec1a21db
Files: Size
configs:
johnm2.cfg 3173
testc2.cfg 3173
johnm.cfg 56421
logs:
current.log 10001
Matrix C2(ro)->show version
Copyright (c) 2004 by Enterasys Networks, Inc.
Model Serial # Versions
C2G124-24 040300089001 Hw:BCM5695 REV 1
Bp:01.00.17
Fw:01.01.11
Hw:BCM5695 REV 1
Bp:
Fw:01.01.11
Matrix C2(ro)->show switch
Management Preconfig Plugged-in Switch Code
Switch Status Model ID Model ID Status Version
1 Mgmt Switch C2G124-24 C2G124-24 OK 01.01.11
2 Unassigned C2G124-48P Not Present 00.00.00
Matrix C2(ro)->
See also: 5605 and 5751.
0 REPLIES 0
