Article ID: 12499
Products
SecureStack C3, C2, B3, B2, A2
G-Series
D-Series
I-Series
Changes
With default multiauth configurations (no commands visible from a 'show config multiauth'), issued a 'show multiauth' query on multiple devices.
Symptoms
No apparent reason why some devices default to "System mode : multi" and some default to "System mode : strict".
Cause
When policy commands are supported - whether used or not - then multiauth mode defaults to "multi". Otherwise, it defaults to "strict".
As a result:
- The C3, C2, G-Series, and I-Series, which support policy with no need for licensing, always default to "multi".
- The A2, which has no policy support, always defaults to "strict".
- The B3, B2, and D-Series, which support policy upon application of a policy license (10833), default to "strict" when unlicensed and to "multi" when licensed.
This is demonstrated below, for the D-Series. Note that upon application of a policy license (
10791), the system attempts to retain the existing multiauth mode by insertion of an explicit 'set multiauth mode strict' command in the configuration. Similarly, upon removal of a policy license, the system inserts a 'set multiauth mode multi' command. In either case, removal of that 'set multiauth mode...' command yields the described default behavior.
D2(su)->show config multiauth
#multiauth
end
D2(su)->show multiauth
Multiple authentication system configuration
Supported types : dot1x, mac
Maximum number of users : 36
Current number of users : 0
Default precedence : dot1x, mac
Admin precedence
Operational precedence : dot1x, mac
D2(su)->set license D2Policy
Terms of this license may be found at
http://www.enterasys.com/support/fla.aspx
Do you accept the terms of the applicable policy license (y/n)
?y
License successfully enabled
#multiauth
end
D2(su)->set multiauth mode multi
#multiauth
end
Supported types : dot1x, pwa, mac
System mode : multi
Default precedence : dot1x, pwa, mac
Admin precedence
Operational precedence : dot1x, pwa, mac
D2(su)->
Solution
Functions as Designed (FAD).
Be aware of the "multiauthentication mode" guidelines as described above.
See also: 10283 and 11246.
