Activate MFA for all users XIQ
JohanHendrikx
Contributor II
I've enabled  in the global  settings  google authenticator.
When I creat a new  user to access XIQ,  this user can login with the username and password.
The user does not need to use the authenticator.
Did I adjust the right setting?
What I want is that all users are required to use the authenticator.
Johan Hendrik System Architect Audax
1 REPLY 1
SamPirok
Hi Johan, that is the correct setting to adjust. Would you be able to add me as an external user temporarily so I can check your settings?
If you'd like to add me, this guide reviews how to do that. To see all the settings I need to see, it would be best if you could make me an operator when you add me. Please use the email address [email protected] to add me.
Please also let me know what your Organization Name is for your XIQ instance so I can find your instance in the list of XIQ instances I have access to. To find your Organization Name you'll want to go in to XIQ> Go to Global Settings> You should land on the Account Details page, scroll down to the Organization Information section and the first line in this section should tell you your Organization Name.
